Do I need new aircraft antennas?
Hey All,
I recently has a hard landing on the left side of the aircraft and was hoping for some help.
I snapped off the front and rear landing gear where the antennas go and seem to have damaged the antenna cables in the process. One antenna was cutoff totally and the other seeming had the wire pulled and snapped internally, meaning the plastic insulation on the wire wasn't broken, but it's stretched thin and I think the internal connection was severed.
I also seem to have damaged the motor control wires, as they seem a little bit squashed, but I can't tell if they're broken.
Having said all that, can I:
A) Solder in new sections of wire on either the antenna cable or the control cable?
B) Buy a new set of antennas and a new wire harness for the left side?
Any suggestions or help would be awesome!
I can post pictures as well, but I'll have to do that in a little bit, as I'm at work at the moment.
ziamedicalcenter
