- Joined
- Jun 7, 2014
- Messages
- 196
- Reaction score
- 59
- Location
- Copenhagen - Denmark
- Website
- www.airflix.dk
Did you do the download?
See the Release Notes:
So now DJI has grounded all Inspire 1 if you don't have a propeller lock - which is not easily available yet. Does this mean that flying now without a propeller lock voids the guaranty? This company is crazy weird.
I don't follow other fora as carefully. Has a photo of the propeller lock been posted? The way I read it that letter, it seems hard not to interpret it as "fly at your own risk if you don't have a propeller lock", although we're not hearing or reading of people's propellers flying off much.
DJI recommends...nothing on warranty nor grounding of aircraft.See the Release Notes:
Indoor flying just got easier with the update. Handles a lot better. Big improvement id say
This is ridiculous - what's the reason for this change?So... Item 6 on the list:
does this now mean that the RTH function only has a 'quoted' accuracy of 65 feet?![]()
What the hell happens if I'm besides a body of water, on the outskirt of a crowd of people, on the edge of a cliff?!? DJI, think, think!
OK, so we agree that this statement basically says that within a 20 meter distance of the home point, the aircraft will make no attempt to reach the true home point before descending vertically and touching the ground, right? That's bad, no? A $400 Blade QX350 hobbyist quad will hit its mark all day long with no bugs or limitations.
Although it's not my primary way of landing, RTH is a valuable function right? And when I set my home point with the expectation that I may have to use RTH, I don't set it arbitrarily. I set it so that it's away from trees, power lines, buildings, people, and even more simply away from irregularities in the terrain around it. With this change, they've basically de-featured the product, telling me that unless I'm in a very large flat area and that I can tolerate such a large variation in my landing point, RTH is useless. Disappointing to me at least.
If there is any explanation for this, I would think it's because people had some awry landings where the aircraft was coming down right over their head (and remote controller) in the dynamic home point mode.
Yeah, I definitely understand your point. I never use dynamic home point (could never get it to work, honestly). And 99% of the time when I hit RTH the aircraft is not really near me. Not 20M anyway.
But you would expect that when you say "return to home" it actually "returns to home". At least within a 5-10 meter circle. The auto landing may freak people out. Once they learn they can pilot it closer as it lands, though, they'll be ok. One hopes...
Hope You're rightIMO, you maybe interpreting this note wrong... What I believe it means is if a RTH is activated and the aircraft is within 20M or 65 feet of the Home Point, it "won't" climb to prescribe RTH altitude...but rather it will descend and land at the home point...
