Flying I1 lower than take off point...
Hey guys/gals. Has anyone ever tried to fly the I1 lower than the take off point? The shot I'm trying to do is from a cliff. If I take off from the cliff and fly the I1 down below, will I lose signal? Is it safe to try?
Yup just keep LOS and all should be good, don't panic when altitude shows negative number as 0 will be take off spot.
Reactions: Pietro Avolio
Not personally, but seen MANY others do it. I have height issues (LOL) if I was to stand next to a cliff I'd probably fall off haha
HA HA. I'm the same. This is the cliff I plan on flying it off of. Below is the Sacramento River and no ground to take off from. Looking forward to trying it out.
That doesn't look too extreme but you might want to practice some before your shoot so you can get used to it..
judging distance and hight can be tricky when flying below your take off point..
Turbo. ...
I have done it of of cliff tops and yes its awkward to guage where you are.. but no signal issues
about 55 secs in so you don't have to watch my crappy video
Reactions: Arriguy
Can anyone explain how the official term for "Loss of Signal"....i.e. LOS. has become something else complete on this forum? Just curious.
I have read somewhere about a RTH issue when at a negative altitude, it seemed that if the safe height was set to 20m for example and you are at -21 that the craft ignored the - symbol and thought it was above safe AGL,
I DO NOT know if this was confirmed as a problem, and or if it was fixed in recent firmwares.
Just posting to make you aware that it might be a problem, I am not confirming that it is.
I try not to go by hearsay and rumour. If I don't know I test it. So I flew a dedicated test flight this morning and the answer is:
With FW 1.4.0.10 and the aircraft flying below the takeoff point and display a negative altitude (test to minus 5m) the aircraft will climb to the failsafe height and return when the RTH is initiated (manually or automatically on loss of RC signal).
However, I did discover a change to the RTH logic that I had not seen before. I had the return altitude set to 30m. With the aircraft below 20m, the aircraft climbed directly to 20m with no heading change. It then turned to face the Home Point (HP) before climbing the failsafe height (30m in my case) and flying back. If the aircraft is above 20m with RTH is commanded, it turns towards the HP, climbs to 30m and then returns.
good for you, I was simply letting the OP know that there was an issue mentioned with this in the past.
Either way its good to know that they have fixed the issue (if it existed)
Reactions: Scotflieger
I was flying by the White Cliffs of Dover last month. Launched from sea level and flew along cliffs. Lost GPS when flying within about 20m of the cliff, obviously due to a satellite blank out. Not a problem if you are OK with ATTI flying, and recognise the issue before Return to Home kicks in, but it is one to be aware of.
in that case it would just go into the landing sequence right ?
Awesome shoot and liked the Enya music as well
