fpvlr inspire1 antennas
I can't seem to get the first cover off the back of the controller took the 4 screws out and it seems like it's glued in
Try the usb socket ,or other may block ur way to remove.. :) becareful after u reach inside... remove the ribbon holder by just pull up the end of the black thing... do not break it.. do it with cautions it shall goes fine.... :D
Watch this video it covers the big connector.
Yes mazz was right ... anywhere here is how it look like unplug the stock one and plug the new one... and drill a 6.5mm hole for the new attena and carefully hide all the ribbon n other cable before u snap it back...
I thought he said he had already removed the cover. Now I realize it was just the first. That ribbon actually took me a minute to figure out how I would do it as well. Not really able to grab it and I didn't want to pinch the ribbon with anything. Seemed to easy to damage. I ended up using a pencil eraser. Just dragged it across the top in the direction I wanted it to come off. Worked for me. Hope that helps.
Reactions: turbodronepilot
You were lucky. There is a locking clip that should be lifted. I flipped mine the wrong way and broke it. Will be sending in the transmitter tomorrow. I didn't see that video until it was too late.
Tested !!!!! Full bar no even a signal drop in radio n video.... I ammmm solo happy with this... :D
Thanks for the info ... i am doing for a huge factory aerial photograph and permission for flying that high... normally my flying height are below 120meter..:D
Ok did a range test. At 400ft could only get to 5200 feet on the auto setting. On a manual channel 6100 feet.this is a stage 2 kit. A lot better on auto. Not much of a gain on manual. I could get to 5400 feet without kit on manual and 2500 on auto
i use with booster... x2 it give me super duper range...
wanna ask if anybody using with the fpvlr advange...
i notice that ver1.2 app display poor signal when u on the booster... i believe it detetecd the booster are very near the radio but doesn't matter
