I did the mod to mine. For about 1/2 the price than the DSLR pro kit.
You need:
A FPV camera ~$25 mines a 2.8mm lense 600tl
A 5.8ghz transmitter. I paid 60 there are cheaper ones.
5.8ghz SMA Antenna's. ~$40
Wire and shrink tube
FPV diversity monitor. I got the Fly sight Black pearl off eBay for 80 with battery.
I gained power for the set up from positive and negative terminals on the main power board (below the battery terminals.)
I simply drilled out the nose cone. There's a perfect moulding spot to centre the drill.
I used some epoxy to secure the camera in place.
Point the camera up more than you think. I had to re do my install as it pointed too far down once installed.
I installed my in a clean way and you can't tell it have the added camera except for the small lens in the nose cone that is mounted flush and the tiny antenna that sticks out the back of the rear LED cover.
As for a review:
it's a must. I had a crash the first day operating with dual operators with out it.
Coming from flying phantoms for years.
We where shooting motocross at lower altitudes and I was politing. As the camera was swinging around constantly it was easy for me to become disorientated in where I was heading. I had to fly 90% by line of sight.
I thought the bird was closer to me that it was and it smashed into a tree. All I heard was an "oh no." From the camera operator.
Thankfully only two props was the total damage. We where back up in sky in 5 mins. This time a little higher and moving a lot slower.
It gives the pilot a proper representation of where the bird is and where it's heading. Even when the camera is shooting behind or beside. My pilot and I have nailed every shot since the instal while before it was 50/50. Plus we fly in close proximity of objects and haven't had an issue.
I now have full faith in my pilot flying my bird while before it was always in the back of my head.
I can see why the
Inspire 2 has it.
I'm currently trying to figure out how to mount a 2 axis FPV camera like the
Inspire 2 onto my Inspire raw.
Currently only one of my inspires has the second camera installed. The second on is going to get it. Every time we put it up we both (camera and pilot) wish for the second screen.
