If the life span is lower than 90% You should take into account that the battery may act unpredictably.
I wouldn't be able to think of any reason to think that way.
The battery life estimation is there precisely so that percentage and remaining flight time indications remain valid as the battery ages.
If you see it drop significantly from one cycle to another then yes you should start worrying, but apart from that a cell or the whole battery can go bad just about at any time.
Based on 10+ years of using Li-Pos in RC you'll have batteries that die after 10 cycles and others that still go strong after 300, and some that are unusable after 3 months just sitting on a shelf while others are still perfectly good after 3 years.
We can hope DJI use decent manufacturers and test their batches a bit more than typical RC suppliers so they should mostly be on the good side of the curve, but individual experiences will still vary.
