Inspire 1 Pro Black / Litchi / Z3 No FPV
Has anyone had any luck using this combo? I cannot get the FPV to work with the Z3 and Litchi? According DJI my Z3 has the latest FW and the X3 will work with FPV just not the Z3. All items work fine with DJI Go.
Thank you.
Thank you.
There was an issue with the Z3 (when set to RAW) but I believe they fixed that.
Have you tried emailing Litchi direct? They are usually very good at support.
.....cannot get the FPV to work with the Z3 and Litchi....
I have a similar issue, X3 works fine, Z3 works with Go and Pix4DCapture, but not Litchi or GSP.
At first it was just black but after recent update I now get the initial view but it then freezes. Tried switching to raw and back again, tried with all combos of having or not having Go running in the background.
I had to change the hardware decoding settings and now I have the FPV via the Z3 using Litchi. Hardware encoding is set to off. Now the issue is extreme drift when yawning during pano shoots.
VanitaYaga
