Inspire 1 X5R Gimbal - do these contacts look ok to you?
Hi,
I have an Inspire 1 V2.0 with X5R gimbal.
I'm having an issue with the gimbal where won't initialise correctly and keeps vibrating and shaking on startup.
I'm suspecting the contact PCB on the gimbal side might be the issue. It looks like pin 6 & 8 are fused or joined together. See attached photo. Do you think this could be the problem?
The pins on the aircraft side look fine to me.
Hi,
Mine is separated
Reactions: James Dar
Hi,
If I remember correctly this is a common issue and the contacts are easy to replace
LavernePre
