The CW quick release props are marked (albeit tiny) on the leading edge near the hub. (1345s CW) The CCW ones are only marked (1345s)
I also think we as pilots should know without markings which way is which in case it is not marked![]()
Oh and put a white dot on CW props.
that is what I was explainingCut the newbies some slack[emoji13] lol!! Easy way to remember is the way the propeller has to turn to lift the craft
I have an Inspire1 Pro with the 1345t props and have about 36 flights on it so far with a little more than 4 hours of flight time and 2 of the prop adapters are starting to get sticky and hard to put on and twist off. I thought it was the prop and tested with a new prop but same thing. I bought 5 sets of these adapters to have on hand just in case something like this would happen so I could replace them and not have to worry. I'm going to replace the set I have on there already for I don't completely trust them and will be replacing them often.
Will keep everyone updated
Woah! how do the t motor props work? and do you have a link to them with the adapters? Also what is the extra battery your carrying?
Use loctite blue. But only a drop on each screw. Less is more.Also do you have a recommendation to what Locktite to use on replacement?
Do you notice a performance increase with the t-motor props? How is the speed with the dual battery mount. I have the x5 camera so Im pretty curious
