problem X5S
My X5S camera when turning sideways makes a buzz and in flight does not rotate, just rotate when the engines are stopped, I've updated inspire 2, but calibrated equal result imu and gimbal. Movement from top to bottom if it is correct does not buzz.
A little buzzing here and there is normal. For the rotation which gimbal mode do you have enabled? Follow, free, and I forget the other one but that can cause it not to turn when the copter turns.
I have reviewed all settings and everything seems correct, the closing is correct I do not find the problem, the strange thing is that everything works when the inspire is on the ground, thank
Moved to X5S section.
Sounds very much like you have selected 'Free' mode in the app which means it will be locked in one position irrespective of aircraft orientation.
TeganSugde
