RC will not charge iphone
Hungary
www.phat.hu
hello :)
for some reason and out of the sudden the slave rc will not charge the phone attached to it...when i disconnect from phone side and reconnect it starts but stop at the same moment (like it would start charging)..
any ideas anyone?
would really need a workaround as i always need to charge the phone up before using it... :(
Hi Phatzo, have you tried to set it to charge the device before you change it to be the slave? Might be worth a try as a reboot.
it did work a while ago.. i modified the 5.8ghz antenna inside(gave it a separate antenna) but on both RC's and the other works fine with charging... how do i change the charge preferences? and where? i never changed them actually...
it was always the slave RC... i am confused now :)
i tried to work around the video downlink problem :(
it did not :( DJI let us down on that one..
i could not make an option out to change charging preferences and it was all of a sudden.. the other day it worked. the bckup remote also does not charge which was previously my slave (have a backup I1 with one RC)...
mb920questions
