SRT file values
Florida, USA
Does anyone know what the "Hs" values are in the SRT files associated with the video files? I believe "Hb" is height in meters, but can't figure out the "Hs". I thought maybe heading, but those values don't reflect the craft's orientation. Thanks for any help.
Looks like it could be "set altitude" while Hb is "barometer (measured) altitude". And Hs has a display bug and is clamped at 25.5m.
Hadn't looked at the SRTs in a while, looks like the format has changed. They used to have more data.
It's telemetry data in the format of subtitles that you can add to your video.
Thanks @Kilrah It appears my Hs values definitely have a bug because sometimes it is very close to the Hb values and change as the Hb values change, then other times it's 0 and other times it's the 25.5. :confused:
