Upgrade Failed V01.10.01.40
I am trying to upgrade my aircraft to latest version, however, DJI Go showing ".bin file corrupted" and unable to upgrade. Anyone of you facing the same issue?
p/s I'd tried to re download several times from DJI website, but still encountered the same issue.
I did the update to the latest firmware on the inspire 1 tonight and after doing everything correctly got a long steady beep which didnt seem normal, checked the text file it said update failed, yet when i check the firmware version in the go app it says its updated to the latest version, tried to update it again, formatted the card reinstalled the bin file on the root of the card put it in says im at the current version so couldnt update, found out tonight you cant roll back anymore, everything seems to work okay on the drone like it should but why did the text file say update failed is beyond me
Because this is broken firmware... do people just blindly update anymore?
ziamedicalcenter
