Vibration Check on X5
Can people with the Inspire Pro X5 with balanced dji 15mm lens please check if you feel a slight vibration on the free moving vibration absorber board where the front two dampers are located.
Please check when aircraft is powered on with gimbal attached, no need to rotate, pan or turn motors on. Just make sure gimbal is powered and try touch your finger on the top plastic which the front two rubber dampers pass through.
I feel a slight vibration on these parts but when I touch the lens it is okay. Temperature is around 30°C which might influence as well.
I really look forward to your replies and a early happy new year to you all!
I've had two and both had a slight vibration in the yaw motor. My Ronin also has a slight vibration from the motors. Even the X3 vibrates very slightly. There could still be something wrong, but all the footage looks good.
apexwebcube
