Zebras won't turn off ??
I don't seem to be able to turn off Zebras, or turn on my Histogram (or color wave form for that matter). When I pull up the menu items, the app gives the impression that I'm turning "Exposure warning" off. It toggles from green slider to white. But the zebras don't go off even for a second. When I click out of the menu and then back the slider is green again indicating they are turned on.
I'm using X5s. I think my firmware is all up to date.
Thanks for any ideas,
Ernie
I just tried refreshing the firmware for the Inspire. Is there a way (or need) to update the firmware of the Gimbal or camera separately. I'm new to this setup. Thanks, Ernie
I just used my Phone instead of crystal sky and the Zebras turn on and off perfectly. Switched back to CS 7.85 (left zebras off before I switched) and still Zebras are on and can't be controlled. When I'm in Auto exposure the zebras do go away.
In case anyone having similar problem, I did a complete erase and reset on the Crystal sky and now it works. I did not reinstall the firmware.
Reactions: Killboydotcom
Fecid1981
