I just need to lament one more time on this topic.
The DJI pack cells are LiHV cells, meaning they are able to take charge safely up to 4.35V per cell.
But they are low C rated (discharge) unfortunately, which while dramatically reducing weight, is one of their fundamental shortcomings.
In less than perfect operating conditions, or with any flaw in the cells themselves, or with unbalanced cell voltage, a voltage sag induced by temperature (hi or low outside the perfect 20C - 40C "Goldilocks Zone") and/or extra load (X5 camera, high speed maneuvers etc), can result in catastrophe, as we've seen reported many times here and elsewhere.
Their low discharge rate, coupled with the FW bugs, extra load of the Pro and other factors has resulted in a very thin margin of error should a voltage sag occur.
Hence the community drive to find alternatives and add redundancy to the DJI packs. (Battery Mod Info)
DJI really needs to add an additional level of redundancy (6S3P vs 6S2P for example) and bump the C rating on the cells.
The current situation is killing Inspire's.
Thank you for listening
