Firmware Update v1.2.0.17 Available
And just to add one additional tip.
ONLY put the BIN file in the TOP directory (ROOT) No other filed should be on the SD card before installing any new Inspire 1 FW.
Also, if it fails, check the TXT file that the FW install/upgrade process creates.
Assuming you used a CLEAN SD card, nothing on it, No files, just the new v17 FW, so After the first upgrade attempt, you well see a new directory for the camera, and a new .TXT file, open this text file you should see a statement successful or canceled of failed.
Just make sure if you try to start the upgrade procedure all over again, remove all old files off the SD card and leave just the BIN file. No others on the card.
Hope this information helps.
Best regards,
Steve
Luke, try to reload the 17 FW again. also, make sure you have the camera is seating on it's fixture. Take if off again and reinstall it.
Also, you have some other main control issue in the Inspire. What's up whit then RED and Yellow LED?
Let us know if you get this resolved.
Best regards,
Steve
The key appears to be starting totally from scratch.
1. Take a new mini-SD card or take one you have and reformat it--wipe it clean of ALL files.
2. To that clean card, copy the new *.bin file from the firmware update folder and THAT FILE ONLY.
3. Put the card in the camera (already attached to the bird) turn it on and let it do it's thing. DO NOT turn on the controller. If after ten (10) minutes nothing happens, then you can be fairly confident that the bird has already been updated on previous attempts. Otherwise the camera will beep and begin a fresh install. Once the tail light goes from flashing yellow to flashing green, you know it's done.
4. Once that's done, turn off the aircraft.
5. Get a new thumb drive or reformat one you have, again, to wipe it clean. Copy ONLY the *.bin file onto the thumb drive just as you did above.
6. Insert the thumb into the controller and turn it on. DO NOT turn on the aircraft. After a minute or more it will start the install. Once it's done, the blue light will turn green.
7. Turn off the controller and remove the thumb drive.
8. Turn the controller on again.
9. Turn the aircraft on again.
10. They should now communicate with each other.
I hope this works for everyone having the same issue I had. Went flying this morning without a single problem. Best of luck!
Hi Steve - I'm following this, but if the aircraft's yellow lights keep flashing and not turning green (end of point 3) any thoughts on what I should do next? Thanks
Best regards,
Steve
Hi Steve the I flew the drone inside with the camera off. The cam seems not to respond to anything.
Another thought:
Go to this thread and read post #18: http://www.inspirepilots.com/threads/v1-2-0-17-firmware-update-failure-solved.1344/#post-13962
Find the file on your SD card (in the camera) and look for the file named in the picture (at top), a txt file. Compare your readings to those in the picture. If they are the same, your bird is updated. So no further attempts at updating the copter are necessary. Just follow the instructions for the controller.
The problem is that apparently the firmware got corrupted on the first update, as I am checking the firmware versions everything tallies up but where it says camera firmware version is blank, I tried using another SD card fresh format with fresh firmware, but the txt file is reading Cancel.
Another thought:
[00004259]Packet [C:\WM610_FW_V01.02.00.17.bin] detected.
[00004267]Packet upgrade start...
[00004288]Packet checking...
[00004295]Done.
[00004300]Version checking[1]...
[00004306][01 00] v1.3.1993 -> v1.3.1993
[00004351][03 05] v34.1.0.5 -> v34.1.0.5
[00004389][03 06] v1.15.4.9 -> v1.15.4.9
[00004401][04 00] v1.5.0.61 -> v1.5.0.61
[00004429][05 00] v2.3.6.0 -> v2.3.6.0
[00004437][08 00] v1.10.0.14 -> v1.10.0.14
[00004454][09 00] v1.6.6.1 -> v1.6.6.1
[00004509][11 00] v3.3.0.0 -> v3.0.0.11 ------> this one is not correct
[00004589][12 00] v1.3.0.60 -> v1.3.0.60
[00004629][12 01] v1.3.0.60 -> v1.3.0.60
[00004669][12 02] v1.3.0.60 -> v1.3.0.60
[00004730][12 03] v1.3.0.60 -> v1.3.0.60
[00004770][15 00] v1.1.1.0 -> v1.1.1.0
[00004810][17 00] v1.0.2.4 -> v1.0.2.4
[00004870][17 01] v1.0.0.9 -> v1.0.0.9
[00004886][19 00] v1.0.8.59 -> v1.0.8.59
[00004892]Packet upgrade cancelled at version checking.
It's reading cancel because it is up to date. That's what I was told.
[00004295]Done.
It is correct on mine. Why do you say it isn't?
So it is correct? Because the number is different. On the thread you asked me to have a look at it reads different can you check?
Thanks. Actually I got it working......seemed that the problem was that the aircraft had updated but the firmware to the RC hadn't....I tried physically connecting the RC to the aircraft using the supplied USB cable and the update kicked in. Seems to be fine now. Shall fly it tomorrow and hopefully all will be well. Thanks for al the help, I hope others have success too.
Great news! Glad to hear you're back in the air! Have fun flying.
Reactions: David Glen Walker
No first flight yet, but first update was a success using what Abe and InspiredOne had posted. Thank you, Abe and InspiredOne.
My update procedure was error free and took me less than 15 minutes for both controllers and the aircraft. It's not exactly the procedure DJI describes but I've never experienced the hiccups some users have posted. When in doubt, follow DJI's directions, but here's what I did:
That's great for those who had no errors. What I posted was for those of us who had issues after attempting to update.
You were one of the lucky ones! :D
webvertifree
