Firmware v1.04.00.10 update - gimbal pitch control lost
Hi everyone o/
I have just updated my bird and 4 batteries to v1.04.00.10 and now gimbal pitch control is gone from the master remote and slave tx's. The pitch control on the app is grayed out/disabled. Update file reports all good.
Now I have only had this bird (in the air) for a little over a week so forgive me if I have overlooked some hidden option in the app.
I can auto calibrate the camera, movement and video feed is fine during calibration, control ISO/Shutter/EV from app and dial, take photos and record video, camera yaw's with left/right rudder input. Just not able to use the left dial to control the camera pitch.
- Stinkys.
Hi everyone o/
- Stinkys.
Have you tried the gimbal wheel to control camera pitch/yaw combined with the C1/C2 to select between them?
Reactions: Stinkys
Bawwwww I just worked it out. Was set to camera configuration 1 which has pitch and yaw EXP of 0 (zero). Not sure why that is, unless that is the default.
Thanks for the reply though Scotflieger.
Reactions: Scotflieger
I had the same problem and was panicked since I have to fly in a day or two. Thanks for taking the time to post the info. I had trouble finding the settings were you were referring to because I was poking around the pilot app without actually being connected to the inspire. The advanced settings do not show up without being connected. So, for the less informed like myself, to adjust the EXP's, be connected, tap list icon upper right corner>tap gimbal icon which takes you to Gimbal Param Settings, scroll down to and tap advanced setting> there you will find the three configuration buttons.
I know this seems pretty basic but I find things more confusing when panicked :-) Hopefully this helps someone.
Reactions: Stinkys
escortsites
