HDMI Module downgrade?
I have a dual remote I1 and the slave transmitter has a bad HDMI module. I've read in different forums that the module can be replaced using the P3 HDMI upgrade which goes for $99.
So my question is this: if I don't need HDMI on the slave, could I replace the HDMI board with the P3 USB-only board that sells for ~$25?
Thanks all!
It will not work with the one without the hdmi port, or it did not for me when I tried.
I could not get my inspire 1 remote to update so I put the USB module from my phantom 3 on the inspire remote and it worked for the update and for flight. The phantom USB/hdmi module would not work however.
Thanks all!
The P3 HDMI module is a direct replacement and will work fine.
Already covered before on the forum like here for instance....
DJI Inspire 1 Remote Repair - HDMI Module
tycet
