I2 motor mount to tube has gaps.
I noticed examining the joint between the motor mount and tube that some joints I can see the gray glue between the joint, while other areas show a clean fingernail-wide gap and no glue present.
I'm thinking of applying some CA thin glue via a pinpoint nozzle to the gaps as a filler and to glue and fill the gaps. Just an insurance should the joint fail and result in a fly-away motor in flight.
Good idea or not? Or is their a better glue made for CF tubes?
Dilly Dilly! - Loctite 9460F faster hardner than 9462 and Loctite 9462 are Hysol epoxy glues but not light enough viscosity for seeping into such small gaps. These products are bragged upon on several RC aircraft website forums, I too am seeking some information on this topic as preventative maintenance.
abseilerstu
