New Firmware v1.3.0.00 Aug 4 2015
HELP .... My inspire dont work any more...
It's only beeping en try to update ... after 5 minutes only the loooooooong Beeeeeep sounds!
This is the record .txt file :
Delete history success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.08.09 11:28:56 =====================
Packet: WM610_FW_V01.02.01.06.bin
========== 2014.01.01 00:00:04 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.08.09 11:39:36 =====================
Packet: WM610_FW_V01.03.00.00.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
========== 2015.08.09 12:33:04 =====================
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2015.08.09 12:47:18 =====================
========== 2015.08.09 12:50:12 =====================
Result: Failed.
========== 2015.08.09 12:51:39 =====================
Result: Abort.
========== 2015.08.09 12:52:25 =====================
Result: Abort.
========== 2015.08.09 12:55:53 =====================
Result: Failed.
========== 2015.08.09 13:09:37 =====================
Result: Failed.
PLEASE ANY SUG?
Anyone notice additional twitchiness? I noticed it yesterday in small gusts of wind.
Wondering if I need to mess with the advanced gains for the first time on this craft.
Already tuned down ATTI and Brake, and sticks are .30 or .40
Yes, I noticed this on bringing the bird back home with a low battery warning, when trying to land with the battery circa 15% it did appear twitchy even in GPS mode.
I had already tweaked the gains with the sticks set at .30 and both the ATTI and Brake turned down slightly.
I have now set them back to default to see if the twitchy behavior dissapears..
Reactions: damoncooper
See my post about 7 before yours - I had a similar problem - no video signal until I start the motors
If I was you, I would check the contacts between the gimbal and connector, they could be only making a contact when the bird is vibrating, also I would check the 2 ribbon cables connecting to the gimbal/camera for bad connections or loose pins.
Reactions: Auspete
image.jpg image.jpg [QUOTimage.jpg E="Aviator, post: 51542, member: 21915"]If I was you, I would check the contacts between the gimbal and connector, they could be only making a contact when the bird is vibrating, also I would check the 2 ribbon cables connecting to the gimbal/camera for bad connections or loose pins.[/QUOTE]
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
PLEASE ANY SUG?
Yes
Delete all the files and folders on your sd card and put the FW_V01.02.01.06.bin file on there all by itself.
Try to downgrade it to this FW file.
If successful, delete all files and folders again and put the latest FW file on your sd card and try upgrading it again.
Did you by chance update the RC before the AC?
If so, you can relink via the app and red button in the fuselage.
Thanks @damoncooper. No, I did the AC first, RC dead last. You can see the order in my 'log' file I attached.
I DID try relinking just in case, but that didn't resolve it. It wasn't 'unlinked to start with'.
Also deleted the GO app and reinstalled. No help.
I have a feeling the camera has been fried somehow.
WHOA, interesting.
Just put a different SD card in and I have picture back!
Although, it's faded out in 'error' as it says 'Slow SD card'.
Going to try a few others and reformat the problematic one and see what happens.
This could be OK...
NOT faded out - ND filter ON ;)
But reformatting the SD card has worked.
Back in action - after a successful firmware update!
I'm breathing again.
Thanks for your suggestion
No pins lost / broken....
This is how The bird sounds
Same issue?
@Auspete I did try firing it up, but that didn't help.
It was reformatting the card that did the trick for me.
Same issue?
Is what the same issue?
I resolved my 'no signal' issue by reformatting my SD card.
Not sure why it would report back as not having a signal though.
Hi @BOO
I don't think our issues are the same, because my FW updates were flawless.
Follow previous advice.
Make sure ONLY the firmware file is on the card.
After an attempted update, review the logs on the card and see what the status is, then delete them - so it is just the .bin file again.
Then attempt updating the next component.
Rinse and repeat until you're done.
For all components, my d-d-d-d started within about 30 seconds.
Others may have different experiences.
EDIT: To be clear :), if you look at my log I attached, it didn't actually like the first SD card I tried. But somehow the one I used to successfully complete the FW upgrade got corrupted.
whole SD formatted en cleared... only bin on it and it still f*cking beeps.... what can it be??
TXT... file stil gives old records inc new ones... is that normal?
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
You installing the latest firmware?
I noticed on your log reports you had FW 1.2.01.6 then you tried 1.3 and so on.
To me what it looks like is the AC is now experiencing a major conflict in FW commands.
What I would do is the turn the craft off, remove the battery for at least 5 minutes then reinstall it. After that I would make sure to reformat your micro-SD card and reinsert firmware 1.3 bin file "only" and try again.
Reactions: BOO and rbrdly
Yeah, I think he said in a previous post he was going to try the old FW on a newly formatted card.
Stick with 1.3 @BOO, it will help us help you </jerry maguire>
Reactions: BOO
Thanks ... i will try !
I whiat for tonight when i turn on my bird
with formatted SD en loaded new FW 1.3.0... Bird is not loaded with any Battery
charlessmith4
