Slave Controller Loss Of Video - Master Still Clear
So, again there seems to be conflicting information.. When I contacted DJI (pasted in earlier response to this post) they stated that it works just like the diagram.
Control of gimbal goes from second remote, through master remote, and up to the inspire..
Video is a direct downlink from the inspire to each remote independently.
Now, I still don't know what is actually true, but this is what DJI Support emailed me directly..
From the manual, no ambiguity:
well I don't know..... The funny part to this is I just went to online support and they just said the same thing I was told before. So who knows at this point...
As aforementioned, I tried running a long HDMI cable from my master controller to the HDMI monitor mounted on slave controller to eliminate the intermittent video signal drop. The work around was a success. I hope this will help out dual operator systems that are losing video signal on their slave controller. I'm running FW 1.0.7 It has the most channels available for video transmission.
I hadn't used a slave radio between the end of January and back then I didn't have any noticeable issues and thus kind of dismissed those reports.
That all changed today though as I was camera op on a shoot with a friend, and it was very clear that the slave radio indeed had much poorer video link performance. I'd get video corruption and dropouts occasionally even right next to the machine on the ground, and increasing very quickly with distance becoming pretty much unusable beyond 200-400m, and total loss beyond about 600m. Had to stay tethered to the pilot and connect my T3 to his controller's HDMI port, which worked perfectly normally.
Back to the workshop we did a little test to eliminate a fault from that particular controller by setting up 3 slaves next to each other and comparing during a flight, and all 3 would show similarly poor performance. One was the slave we used on the shoot, the 2nd was my slave, and the 3rd was the master of a 3rd I1 set. The first had an Nvidia Shield as display, the 2nd an iPhone 6, and the 3rd a Galaxy S6. The pilot had a great feed at all times. The mix if devices seems to point the problem to "being slave" indeed, with mobile device type and whether the controller was delivered as a master or slave not being contributing factors.
Friend has flown a few times in dual op setup inbetween but with inexperienced camera/drone operators who'd have had no idea of what to expect and were just probably happy as it was, so it's hard to know when it started and if it was borked by one of the firmware updates, but there definitely seems to be a problem there.
I can +1 that observation. Poorer video on slave, but the channel switch-related complete and unrecoverable loss of video feed is confirmed fixed.
We've been having exactly the same issue - we had no real problems until the last 2 firmware versions . On a recent shoot for a TV ad my Cam-op had unusable video for most of the flights with the video dropping out on the slave remote even when 2 metres from the aircraft. The Master Controller signal was fine with a rock solid signal.
To rule out device or hardware issues we performed tests with different devices & even reset the remotes and swapped them so the slave was bonded to the aircraft as master. Yet the problem still consistently occurred with the slave remote.
Both devices are on the same App version, all hardware is on the same firmware version.
Our next course of action is to see whether reducing the video bit rate improves anything or setting image transmission channels manually helps.
I have a feeling this is related to some kind of timing synch error on the local 5.8GHz link between master & slave controllers - I've raised it with DJI but no response yet ... So in the meantime we'll be tethering a local display from the Master HDMI output.
We should ALL report this to DJI. They listen to issues where there are trends/many reports. Please report this to DJI support and we may have a chance of getting it fixed.
Me should ALL report this to DJI. They listen to issues where there are trends/many reports. Please report this to DJI support and we may have a chance of getting it fixed.
Totally agree I have already reported but if everyone does this we might stand a chance ! The fact is we never had issues to start with so something has been changed somewhere in the firmware or Pilot app..
Having the same problem too...
With a new bird, 3 hours total flight time; the slave have worked flawless for about 15min. I have tried Ipad mini 2, Hdmi output etc. Running a long HDMI cable from master till solved.
DJI Ticket sent
DJI Ticket sent
I'm having the same problem too.. Funny thing is, it worked for 2 days.. Then it decide to have no signal on slave RC. Camera control and functions still linked to master.. Just no visuals.
How do I send DJI ticket?
you send them an e-mail. depending where you are (country) - check their homepage for more info on whom to write to exactly.
in most cases they will ask you to send it in after probably trying to go some possibilities through with you that did not work out.
I have the same issue. the slave loses video feed after a bit but master is solid like a rock. I am not sure if the 5.8Ghz link is the problem and the fact that I am standing too close to my operator. there was a thread where a member solved the problem (for him it worked) to unscrew the the screws holding the camera chip mount (the one that has the cap on the AC side) by half a turn. I will give that a try and report back.
Hello All,
So what was the final solution, if any, to this? I'm experiencing this now as well.
Master/iphone6plus - no drop outs.
Slave/ipad mini 3 video drop outs.
Con't contact DJI. They never respond. Help please. Thanks.
Hello All,
In my case the solution from DJI was to send both slave & master remotes in for inspection & repair. I eventually persuaded our local DJI dealer (who we purchased the unit from) to do this and they reluctantly lent us two new remotes, which worked perfectly. They could not reproduce the fault themselves and they really did not believe there was an issue.
Anyway roughly 2 months later DJI got back in touch and sent 2 new remotes under warranty.
Interestingly this seems to be an issue which only affects apple devices, turned out our dealer was testing with older android devices and couldn't replicate the problem at all.
Since then everything has been OK ( touch wood! )
When I did tests about that we used 4 different remotes from different batches, and a mix of android and iOS devices - all combinations exhibited the problem.
I have two of version A remotes. I also have that problem. then I just plug in the HDMI to master and let the camera op go from there.
but would be nice to know what is causing the problem without the NSA game DJI is playing with telling NOTHING at ALL which lets me have the feeling - you tell me everything and I can do what I want with your data (flight logs, flight records etc) but I won´t tell you **** :P I understand company secret but some things are sayable to solve a problem. if turnaround would not be 2 months I would send them in for check and replacement (if needed). but now I would prefer a workaround I can make.
