Solid green on slave
B495E349-0E3F-4EC9-AA5E-6859EF9CD6C2.jpeg current firmware and software all around
Standard Controllers
CS 5.5 on master
CS 7.85 on Slave
Normal operation until this morning.
Started as usual. First AC then Master then Slave.
Master shows solid green
Slave show solid Purple then changes to solid Green when AC is connected but never goes to solid Blue which it always had before.
According to the manual, it should be solid Blue. See attachment
Flew short test anyway and the remotes and AC acted normally. Master has full control of the AC and Slave has full gimbal control.
Any ideas about this issue or whether it has the possibility of impacting flight?
Disregard. The sunlight made both leds look identical. Once inside on the bench, the blue looks correct. Hahaha. Pick another color DJI. One that doesn’t colorshift in sunlight. You’re freaking out your customers.
Reactions: slim.slamma
BobbyJarre
