USA Vs UK Controller
UK
Hi Folks,
I have a UK sold Inspire 1 V2 Raw with dual remotes.
I have access to a USA sold Controller which I would like to use as an additional monitor for the client.
The UK master controller and the USA controller do not seem to see each other when trying to link them.
Does anybody have experience with this or am I flogging a dead horse.
Hi Folks,
They are identical with no physical differences.
The only difference is software controlled to throttle back to 20dbm/100mW in Europe which is controlled by geographic location (GPS).
You must be setting/doing something wrong if it will not work with the UK one.
One thing to try (if it was used in the USA last time) would be to make the USA one the master, then allow it connection via the app to the internet. It will then 'see itself' as a European remote.
Then make it the slave and it should work.
Hi Editor and AeroMirage.
Thanks for your suggestions. Got around to trying again this evening.
Turns out the controller was not on the latest firmware and would not talk to the master remote.
Interestingly enough I could make it the master.
Now I have the UK Tx's as master and camera, the USA remote as monitor.
Reactions: The Editor
topofilm
