Weak signal
Inspire 1 v2, 2500' downrange 400' altitude, getting weak transmitter signal warning. Didn't expect that till at least 5000', any insight?
Moved to Help Section
Have you tried using the search function?
Weak/No Image Signal
Weak signal associated with flight orientation
image transmission signal problems
Weak signal
Weak Signal ?
Signal Issues
There are many more threads covering the same problem.
Weak signal
Weak Signal ?
Signal Issues
Thanks, just putting it out there for any fresh ideas, usually fly los but there are times doing property surveys los not 100% of the time.. thanks again
The area you were flying in has a big part to do with it. You can use these range extenders believe it or not they do work. 09E094CE-9736-42C2-B707-634272FC7308.png
You really dont know about your surroundings. We have been flying at a 300 acre or so site. We always seem to have problems that are just too weird for normal explanation or logic. Compass problems, magnetic interference, signal loss by transmitter or DJI goggles. We thought it was gremlins or aliens. One day we were talking to a local guy who informed us that the area was once a gravel pit and to eliminate having to move the towers, conveyors... whatever was there they just buried it and moved on. Thus in flying in that area is not conducive to normal flight. This ts just a story about my experiences not meaning to explain anyone else's problems.
Reactions: Garbear75
