Configuring slave remote settings
Tampa, FL
Could use some pointers here on setting gimbal controls up for second controller.
How can yaw and Atti be adjusted for the second remote? How about tilt gimbal wheel speed? I think they're under advanced settings but I can't seem to access Mode from the slave controller.
Any suggestions on C1/C2 config for slave?
Lastly- for either remote- where is the pan stick exp curve and yaw exp curve setting?
Thanks in advance!
It's in the "radio" icon -> Mode. There's no expo for camera control at this point but you can set the sensitivity.
Reactions: Ascender
Thanks, Kilrah!
By the way, I always learn a lot from your posts. It's evident that you know your stuff, and I'm appreciative of you sharing your knowledge.
Reactions: Kilrah
