Yaw input stopped working mid-flight with Inspire 2
Flying over the ocean today my yaw input stopped working 10min into the flight. I'm using the standard controller and everything was up-to-date and fully charged. Returned safely flying sideways. Power cycled everything on the ground. Next flight same thing happened 5 min into the flight 😟 Has anyone had this issue before and maybe know what the cause/fix is? FYI I went home and recalibrated IMU and compass.
  • Wow
Reactions: Phil DeVore
Change controllers and see if the same thing happens. If it doesn’t then it’s likely a fault of the controller rudder stick (potentiometer). I’ve had sand in mine in the past, but if it’s a complete disconnect it could be something else.
