App disconnecting from controller ?? Holding C1 or C2
Hi Guys,
Found a bit of an issue this weekend, still new to the inspire series.
On my inspire 1 controllers (GL658C & GL658A), both have the same issue.
On the ground or in the air, holding either C1 or C2 (not together), seems to disconnect the app from the controller almost like a blip in the video/communication. Then it resumes back once C1 or C2 buttons are released. Its almost like it allows you to "tap/click" but not hold the C1 or C2 at all.
Aircraft will not be affected, and video seems to continue to record normal but it certainly drops the signal.
Has anyone experienced this or found a way to disable it ?? I have the C1 and C2 buttons set up for my yaw reset and yaw/pitch control so i cant use them in flight unless i just press them quickly and never hold.
The second i hold either button alone for a 1-2 seconds, bam reset app and then it fades in on its own again.
Thanks in advance.
