Help needed connecting new remote to aircraft
Hello all, new to the forum and have a question for more practiced hands.
Old remote my inspire 1 went bad, usb port was the culprit. Craft was purchased in February of 2015, have never updated the firmware. I have used it pretty infrequently since purchased, with no issues at all. I went several months this year without flying, and tried to get it out last week and discovered the remote issue.
Long story short, I am now in the possession of a new remote (which connects to my device like normal) which is using the firmware v1.4.7. It will not connect to my craft as I expected due to the different software, and now I'm needing some help on where to begin. I have tried pulling v1.3.00 off the site and following the instructions to a T, but the craft does not begin its update. Is there an earlier firmware update I need to install first? I assume they all needed to be done in proper succession.
Edit to add: Would it be possible to downgrade my rc firmware far enough to be able to connect to the craft?
Thanks in advance for any help,
Jace
Is your Inspire 1 out of travel mode for some reason it has to be out of travel mode to do the update. I had a problem once when I updated my controller first while the Inspire was in travel mode.
My memory is short but I believe without connecting the controller to aircraft I couldn't download an earlier firmware into the controller. I actually ended up linking my controller up to my phantome 3 aircraft then was able to downgrade the firmware to an earlier date.
Did you try calling DJI support.
Thank you for the response! Ended up trying 4 different brands of SD cards for the update and one of them worked. All good now.
Reactions: Richard in ky
Glad you have it sorted now but......you could have just replaced your USB module on your old remote very cheaply.
It is a spare part that is readily available and takes 5 minutes.
