Unable to record past 30 seconds while holding Inspire
Charlotte, NC
www.colegentry.io
Hey Inspire peeps so I was trying to take advantage of the gimbal attached to our Inspire 1 by taking the props off, holding it and simply recording. Obviously without the motors spinning but with the landing gear raised. For whatever reason the recorded footage becomes corrupted after about 30-40 seconds on every filming. Anyone had this issue and found a solution? I know its a bit of a weird use case.
I did this today, but didn´t had the landing gear raised. Worked flawlessly..
Have you tested with another memory card? Formated the card you used?
isabellesargood01
